RCU Forums - View Single Post - Another Beginner Build - Sig Somethin' Extra
Old 08-18-2005 | 08:26 AM
krossk's Avatar
krossk
My Feedback: (27)
Default RE: Another Beginner Build - Sig Somethin' Extra
I've used wood glue almost exclusively and don't regret it a bit. I find that the extra forced drying time keeps me from rushing headlong into mistakes.
Do yourself a favor and pick up a Sullivan tail-wheel. With a *very* minor mod to the bracket, you can use the stock flying wire mount point on the bottom of the fuse. Add another blind nut and you're all set. You might also want to reinforce the landing gear plate with some additional balsa triangle stock. There have been some complaints of gear ripping out on rough landings - but that may be more prevalent with aftermarket gear used for prop clearance with larger engines.
Otherwise, it looks like you're off to a good start. Just remember - we like pictures. Lots of pictures [sm=wink.gif]
