RCU Forums - View Single Post - Sig LT-40 Build (maiden a success!!)
Old 08-18-2005 | 01:00 PM
  #33
bruce88123
Default RE: Sig LT-40 Build
IMO if you were to use a wider tape, 2 or 3 inch (do not exceed fuselage width), you would add significant strength to the joint without a major weight penalty. Be sure to use 30 min epoxy to give enough working time and the strength. You could use the heat gun to thin the epoxy a little for great penetration. (do not thin chemically here)
Anyone have a disagreement with that suggestion?
