RE: Radio interference
I personally will only fly a PCM reciever in a gas powerd model. They are not much more expensive and again, why take chances. I'd rather put 50 extra bucks into the radio then 1500 bucks into the ground at the end of the field. Also I use Dave Brown fiberglass push rods for my throttle. The plastic ones can affect your idle trim settings with air temp changes. Jeff
