RE: Glitches
Yes this is my first gasser and also I bought it already built. It is a Stinger 120 and I have made two mods. I changed metal throttle to Gold-n-rod, and and rerouted the antenna outside staight down and staight to the rear. What do you mean mounting the switches on engine side? Also I've been told to twist all switch wires and servo wires. Where can I get info, and or purchase glitch busters. Sounds obvious what they do but could you explain? What about the bolts running through the firewall attaching the motor? Will this cause any problems?
Thanks in advance
Tommy
