RCU Forums - View Single Post - 4WD Problem
Thread: 4WD Problem
Old 08-18-2005 | 03:47 PM
snowbl!nd's Avatar
snowbl!nd
Default RE: 4WD Problem
ORIGINAL: Ahab
but a problem with short drive shafts falling out of diff cups can often be solved by cutting a small piece of fuel tubing to act as a spacer in the diff cup to hold the shaft in place.
Using small rubber "o-rings" works just as well as fuel tubing if you have some lying around...
