RCU Forums - View Single Post - Controller won't work with serial cable
Old 08-18-2005 | 06:13 PM
DuneRider
Default RE: Controller won't work with serial cable
Yo, I finally got mine working last night. You have to read a bunch of fourms... But I am using a serial to usb cord on my dragonfly 22d controler. It really should not make a difference.. Did you down load PPjoy? If you did not then do that get into that program go to ppjoycom and put it on Zhen Hua 5 byteprotoco then turn on your controler and now it should say reading serial stream, open up fms and go to control, select vitrual joystick. Go to maping and configure your joystick and play. If that dont work come back to this site and type in the search fms and read more fourms there are alot on here to help thats how I go mine to work.. Hope this helps you...GUNNY
