RE: A good 2nd plane...
Hey Chris, An Avistar can be pretty aerobatic and fly pretty fast depending on which motor you have on it. The plane is pretty tame if you have a low power engine on the front or under powered with e conversion. If you were running the plane on e power and the performance is low (the plane flys slow and easy) I would say try running it on a hot glow engine such as an OS 46AX. The performance difference will be worth it! If this bores you, then you need to step to a higher performance plane. A Goldberg Tiger 2 would be a good choice or a plane called a Super Sportster! [8D]
