RCU Forums - View Single Post - NACA 2412
Thread: NACA 2412
Old 08-19-2005 | 01:55 PM
BMatthews's Avatar
BMatthews
Default RE: NACA 2412
ORIGINAL: danijelc
Ok,thanks to all of people who gave me information about airfoils,but i have one more question.
Dihedral?Is it same value for low wing and high wing planes.On my high wing model(72" wingspan) is about 4 cm on each wing.
On new model i will use NACA 2412 profile.
Thanks!
Danijel
On low wing models some dihedral is often used to avoid adverse rolling tendency when using a lot of rudder. The old Topflight Contender was a good case in point. Low wing with no dihedral at all. When trying to wingover or knife edge folks report that the model wants to roll away from the yaw slightly. Even a couple of degrees of dihedral in that case would have stopped that tendency.
So a 2 or 3 degrees would be a good thing. If you want the model to be self righting to some degree you'll need more for a low wing, as much as 4 or 5. If you intend on three channel control (no ailerons) or want even more self righting ability then more is needed. For this last case there should be enough that the wingtips are at least as high as the thrust line as a general rule of thumb.
