RE: my cnc
project cost is still to be defined, but lets say complete ready to run it should be around 1900 USD...
this is expensive but don t forget one thing...the cutting area is at least 90x60x40mm.
the frame is 10mm flat bar plain aluminium and 5mm angles, so it is rigid and strong.
it is adaptable for dremelsR tools and makitta trimmers.
the speed should be around 24cm/min with a nice precision (enough for our models).
at the moment there is only standard threaded rod, but if I put ballscrew then it will be much much faster and precise...but more expensive.
I might be able to sell some throw a local company in the UAE, but this is still not determined.
