metal won't bend during high load or rpm meaning less loss of power. with plastic prop advantage i think is more on safety, let say ur prop hit something then the prop will absorb the impact instead the shaft or even the hull which is less damage compare if ur using metal prop.
ORIGINAL: Nitronutt
What are some advantages of metal over plastic? Has anyone tried the same diameter and pitch in both to compare?
