RE: .28 in a funfactor? oh dear....
All I need to do now is get the wheels and run the truck to check the turning and suspension setup. I still haven't gotten around to doing the rear yet. Thinking about using dogbones for the rear if I can fit them.
The only problem that I have encountered so far is the down travel of the arms. The upper arm contacts the cup when the arms are relaxed down all of the way. I am pretty sure that I can clearance everything enough, there is more than enough material (almost 3mm thick) on the cups so I can shave them down a little and I don't want to remove material from the arm if I can help it.
I will get the part numbers to what I am using this weekend and post them. But I cannot recommend this mod until it is complete and thoroughly tested which unfortunatley won't be for a couple of weeks because the kids need school supplies.
As far as pictures I am still dealing with the missing digital camera.
rolland
