RCU Forums - View Single Post - elevator is not perfectly parallel with wing
Old 08-20-2005 | 01:54 PM
Dr1Driver
Default RE: elevator is not perfectly parallel with wing
Full throttle should be used whenever he wants to use it. Pylon racers run wide open 100%. Many sport guys like to go fast, and the Kouger is built for speed. Using less throttle to compensate for a surface misalignment doesn't work. Fix the problem, not the symptoms.
Dr.1
