RE: P 120 starter O Ring replacement
Hi Paul...I personally remove the starter from the engine to replace the "O" ring. Not a big problem, just remove the purple front cover, unsolder the starter leads (remember to mark which post on the starter the blue and brown wire go on re-assembly and you're off to the races. The old "O" ring is sometimes tough to get out, just use a pointed dental probe type tool and it works fine.....Ron
