RCU Forums - View Single Post - professional home build ignition new update
Old 08-21-2005 | 05:59 AM
OLD_SLOW and in the WAY's Avatar
Default RE: professional home build ignition
will these ignitions handle 20,000 rpm? and can you back off the advance at will.
basically what i need is a couple degrees retard at start then pull 30deg or so then near 18,000 back off advance a couple degrees. this is for a gas zenoah/sikk engines in a boat application
