ORIGINAL: Lowlevlflyer
You are just a little too far forward on your main gear placement. On my LT40, the front edge of the main gear is right up against the BACK of the fuselage former that is at the leading edge of the wing. This way, when the aircraft rotates up onto the mains on takeoff roll, the mains are directly under the leading edge of the wing, and when the aircraft is sitting at three point stance, the wheels are slightly in front of the leading edge. I've been flying mine like this from day one, and have had no problems with it. The ground handling is perfect, takeoff roll is well behaved, and the landing rollout is fine. No controllability problems at all.
Thanks for the info Lowlevlflyer. Not questioning your experience, but most of the taildragger conversion threads I've read on RCU regarding the LT-40 suggested the placement I have an image of above. I have my gear mounted now... guess if I run into trouble down the road I can move my gear back a bit.
somegeek
