ryobi 31cc conversion
I don't have any pics but i probably can describe it. The Jag muff is a two piece unit that is circular with the out tubes rotatable 360 deg. Make two holes one on each side of the main body slightly larger yhan 1/8 in. next coil two tubes of 1/8 brass or stainless slightly larger diameter than the ID. of the muff. I wound one clockwise and the other counterclocwise with about 1 in. left strait to put through the holes you drilled.P.S. you may have to slightly angle your holes to be able to guide the strait ends through to the outside .Now use Hi temp. RTV. on the inside around the holes . If you made your coils a little large they should spring outward holding them in place, lastly squeeze the ends a little to make the oil spray when coming out and direct the ends towards the exhaust a little. Now bolt the back on and your finished use a tee to feed both sides just like the slimline mufflers do.
