RE: BME 110x
How much room do you have between the carb and the cowl, I once had to cut a hole below the carb, it was to close. It responded similarly to what you have explained.
Have you adjusted the needles also?
Did you run a line from the metering side into the fuse? and is the fuse not being pressurized somehow? If all else fails let the line dangle out the bottom of the cowl.
