I was just about to glue in the floor of my 4*40 below the tank when I had a thought...
"Should I drill a hole in the bottom in case the tank leaks?"
I had a small leak in my LT-40 due to a loose hose. It was not a problem since I used 3 coats of dope to fuel proof it
I am going to fuel proof the floor as well, but then I thought if I put a hole in it, I could see fuel as it came out... What do you think???
