RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 08-22-2005 | 04:07 PM
  #277
RysiuM's Avatar
RysiuM
Default RE: gas fuel with glo plug no ignition
ORIGINAL: av8tor1977
Well, I'm thinking the sound you are hearing is probably detonation or preignition.
Just had another thought... Normally these small motors don't need high octane fuel, but this is a special case. I wonder if you used premium gas for your mix if this would help. Pretty easy to try...
I talked to the 'car racing guy' and what he said, the Nitro will not cause preignition. The same with methanol.
I remember, when I was using 50-50 mixture, I used 91oct gasoline, but for nitro test I used 87. So you might be right that the pinging is caused by using a gasoline with not enough octan grade. I think this will call for my next test: mixing 91 oct gas with methanol and glow fuel. I have some premix 91oct gasoline with Motul oil 1:33. I will need then less oil from the glow fuel, so I will need to use higher nitro content. I have some Norvel fuel (35% nitro) so I will mix:
0.5 oz of Norvel fuel (35% nitro)
3 oz of my 91oct gas/oil mix (1:33)
2.5 oz of pure methanol.
This will give:
45.6% Methanol
48.5% Gasoline
3% Oil
2.9% Nitro
Let's see if I still hear pinging.
RysiuM
