Im sorry guys, I do plan on finishing it up. Ive been SUPER busy lately.
I recently started a new company that manufacturers high-end electric foamy model airplanes, and its taken all of my free time to get it up and running. You can check it out at
www.revolutionaircraft.com
I will finish the thread...I promise.
Ill try to get started this weekend on taking more pics, and finishing up..
Oh yeah, and the 1/2" thing is with the throttle stick at 0 throttle, and the heli in normal mode. This is so that the blades are at 0 Pitch at 0 throttle. If the swashplate is not 1/2" down from the top of the main shaft, you will end up with un-equal travel in idle up mode, limiting either positive pitch or negative pitch depending on whether its high or low, and it can damage the servos, as it will bind when it hits top or bottom.
