RE: Incidence Problem?
have you measured the incidence with a meter? if it is slightly off you maybe able to shim the wing to bring it closer. since I have not seen it or know how much it is off it is hard to tell. what is the incidence of the wing and stab to the thrust line of the aircraft?
