RCU Forums - View Single Post - .28 in a funfactor? oh dear....
Old 08-22-2005 | 06:12 PM
  #205
rolland
Default RE: .28 in a funfactor? oh dear....
Here is a list of parts that I used.
Diff cups, http://www.acehardwarehobbies.com/2....oducts_id=6652
These need to be shortened 1.5mm and flats ground to slide into diff. Taper ends in for clearance and clearance the underside of the arm a little bit.
Nuckles, http://www.acehardwarehobbies.com/2....oducts_id=6607
Axles you will need 2 of these, http://www.acehardwarehobbies.com/2....oducts_id=6659 and the pins need to be filed down so that they do not protrude out of the diff cups.
Traxxas pivot balls, http://www2.towerhobbies.com/cgi-bin...33&FVPROFIL=++
Traxxas piviot ball caps, http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
The spacers that Traxxas uses on their pivot balls is not long enough so I used some extra shock pistons as spacer, 2 on the top and 1 on the bottom.
So far every thing is working great but I need to get some longer turnbuckles to hook up the steering.
I found my camera but I keep getting DNS errors every time I try to upload. Even if I try to upload to my gallery.
rolland
NitroPete83 (06-13-2020)
