RE: .28 in a funfactor? oh dear....
I need to get the buggy tires and longer turnbuckles for the steering before I really thrash it but so far the brake is holding up fine. I also have the aluminum brake seat and the metal disc and plug.
I never really thought about tire choices for my MT2 but I really like the looks of those Ofna Brick Pins but I am also thinking about the Zombiemaxx (real soft and sticky with a low profile). I also found asphalt tires (slicks) on buggy wheels. When I get tired of the buggy wheels or when the LHS has the parts in stock to finish my conversion I will probably go with the larger tire.
The link Scouser posted on the Hyper 7 uses the same length CVJ's as the Swift the only thing I am not sure about on the Hyper 7 parts is the shaft diameter of the diff cups. The Swifts are the same size at the MT2's.
Power Racing is no longer making the Swift but they sold the design rights to Rdlogics and they are re-introducing it as the SHO Buggy.
When you figure out the bearing problem let us know. I have know idea what the problem is.
rolland
