RE: Incidence Problem?
find the center line marked on the plans that will be your reference point. with the plane sitting stable on a surface adjust the incidence meter while it is on this center line to 0. after this you move the meter onto the wing and it will tell you the deviation from center. you can then compare it with the stab incidence.
