RCU Forums - View Single Post - 63FZS
Thread: 63FZS
Old 08-22-2005 | 08:41 PM
MustangAce's Avatar
MustangAce
Default 63FZS
I have had some trouble after receiving my engine from you guys a few months ago. Dirt in the regulator was the problem. The guy tested it and ran great. After a few flights and retuning slightly, trouble. Compression is way off now. It has two points of compression now. Very weak also. I can turn with one finger through both points of compression without kickover and worrying about damage to my finger not good. Did i get it too lean? Also while adjusting it intially(here at sea level), it kicked back and stopped. Two separate times. Too lean? I put it on a shelf a while back.
MA 13/5 prop
30% heli fuel
Had it tached up to 11,600. In a hover or on the bench it dies off after several seconds and looses power.
Is it toast?? Please help.
p.s. My 110FZ is pulling my Mustang like a turbine. Runs like a top.
