RE: gas fuel with glo plug no ignition
Hi,
I have to disagree with the car racing guy. All the model airplane glow engines need lower compression to use more nitro. Often times when you use more nitro than the engine was designed for, you have to add head shims to lower the compression. Nitro itself burns slowly, but it raises the heat of combustion, and therefore requires less compression to avoid detonation or preignition.
AV8TOR
