RE: Tiger 60
Something I often do is to use a combination of CA and wood glue. Take for example a Cap Strip on a rib. I add a tiny bit of Medium CA to each end, and one spot in the middle, then run a bead of wood glue keeping about 1/2" away from the CA (Actually, I do that in reverse order - lay two beads of wood glue, THEN add the CA so it doesn't have too much time to harden).
Now lay the piece in place, hold it for 20 seconds or so, and the CA will hold it in place while the wood glue dries. No pins, no clamps, no nuthin'
For something like the Goldberg Fuse sides, tack it all together with Medium CA, then go over all of the seams with wood glue
