RCU Forums - View Single Post - Troubleshooting throttle circuit. Lets compare notes
Old 08-23-2005 | 08:43 PM
Kevin Greene's Avatar
Kevin Greene
My Feedback: (85)
Default RE: Troubleshooting throttle circuit. Lets compare notes
Don has made some very valid points...Always check for a mechanical problem before getting into the electronics. If it does turn out to be in your electronics interface that you made (voltage drops so low that the ECU sees it as an off state) you might want to contact Matt (aka Mr Matt). He knows the ins and outs of the JetCat engines and is an electronics genious. He represents JetCat in the turbine forum.
Kevin
