RCU Forums - View Single Post - Troubleshooting throttle circuit. Lets compare notes
Old 08-23-2005 | 08:43 PM
ghost_rider's Avatar
ghost_rider
My Feedback: (20)
Default RE: Troubleshooting throttle circuit. Lets compare notes
When I had such a problem with my RAM-100, I programmed the ECU with the trim at the middle, then after startup, I will bump the trim to max. Whenever you chop your throttle to min, your trim is at Max and above the low throttle shutoff hence preventing the turbine from sensing low throttle pulse which in turn will not allow it to shutdown.
