Hi Bob
It sounds to me like your throttle pot is over travelling when you release the throttle. Follow Ghostrider's suggestion about adjusting the trim point.
Ed
ORIGINAL: lugebob
I am try to troubleshoot an intermittent "RC-OFF" conditions, that I think is being caused by my un-conventional throttle circuit on the Jet powered streetluge. Occasionally, when I let the throttle off quickly while traveling at speeds over 70 mph the P200 flames out. I was able to keep the ECU alive long enough to get back to the pit area a few times and each time the reason was RC-OFF. I have moved wires and banged things around trying to simulate road vibration with it running to see if maybe I had some loose wires or connections, but could not cause the condition. I am beginning to suspect the mechanical to electrical interface that controls the Pulses in to the ECU. Perhaps I do not have enough throttle range (min to max), causing it to be extra sensitive, although it seems like I have plenty.
Short description of circuit- Throttle cable pulls on a spring loaded Throttle Pot (potentiometer 0-500 ohms). Trim switch, switches in a 100 ohm resistor in series to the throttle pot. This feeds a PIC's chip programmed to make very stable pulses (simulates RC Receiver) that feeds the ECU (Jet Cat Version 5.0 )
Here are the numbers I get when doing the Learn RC procedure
Throttle @ minimum =683 to 688 (varies slightly due to mechanical slop returning throttle to minimum)
Trim @ Maximum = 794
Throttle @ Maximum= 1232
My assumption is that when I released the throttle, that the count would have to go below 794 to get an RC-Off condition
Throttle action seems to produce a steady up or down count as I move it throughout the range.
What numbers do you get? is there a norm? I dont think it matters what engine it is, just the ECU and Receiver combo
Thanks in advance for your help.
Bob
If you've missed it, I posted a link to the video of the drag race run from this weekend in the other thread and one of J34 powered jet cars
[link=http://www.jetluge.net/video.html/jetlugedragrace.wmv]Jet Luge Drag Race.[/link]
