RCU Forums - View Single Post - .28 in a funfactor? oh dear....
Old 08-23-2005 | 11:56 PM
  #213
rolland
Default RE: .28 in a funfactor? oh dear....
Is there a possibility that the clutch is shimmed a little too tight causing extra pressure on the bearings when the clutch bell is bolted on? I was thinking if the bearings are "pinched", even a little when the clutch bell is installed it will not allow them to rotate freely causing excess resistance which might be causing them to overheat. Just a thought.
I should be able to get the wheels and turn buckles this weekend. If I do I will give it a good thrashing and post the results. I am going to have to use adapters on the rear until my LHS gets the parts that I need to do the conversion.
rolland
