Echo 44CC Conversion
Weight can be taken off..The carb faces sideways in the saw and is on the opposite side of the exhausts..It will work sideways but is better straight up..The cylinders can be turned 180 degrees to put the exhaust on the same side as the carb...The cylinders have locater pins that need to be changed to rotate the cylinders, and the bolt patterns are not symmetrical as well..Can be done....Been there......
