RE: Showtime
My showtime has a moki 1.35 inverted on it. had to move the stock tank due too the fact that the fuel would just flow out the carb. So moved the tank back to the wing tube put in a 2 oz header tank and a Conely pump. Have a 90 degree bisson pit muffler on it and order a inverted one so it should be completly in cowl. have 6 flights on it and flies great. No engine outs Unlimited verticle. hovers and pulls out no more then 1/2 throttle.
did not Weight it yet.
Dislikes:
Put Hitec 5645 dig. servo all around and the carbon control horn seems to twist. So ordered alumium horns.
Stab halves comes lose after a couple of flights so probaly will epoxy them to fuse.
Tail wheel is very sloppy. But used it.
Plane will flip over when alot of elevator is used. Very bad habit
This is my first attempt with 3d so I cannot comment on that part. But it does go were I tell it to and slow down to a crawl on landings with out dropping a wing tip. which is good so I don't catch a SFG.
Does any one know were to get some extra 4-40 nuts that are on the SFG's?
