Servo issues
Hello all, well I finally got this engine running very good and still going through the break in process, my issue is I have an older futaba conquest transmitter and the "indirect system" servos meaning they turn clock-wise, were as for my nexus the servo arm is not even with rod which connects to the throttle lever, so basically it does not let me get wide open throttle due to the angle. After checking my buddy's nexus his servos turn counter clockwise, so is there anything I can do to modify the servo to turn counter clockwise? or should I get a s148 servo as a replacement? if so will have 2 different servos on a reciever work fine?
