Hello Kiswa,
I am just returning to R/C flight myself after almost 20 years. I was a glow person way back when (Northeast Aerodynamics Train-Air 40) but I decided to go the electric route on my return trip.
I have a fairly good-size hangar of electrics now, all RTF (luv that instant gratification:
). I started with a Shun-Da J3 Cub, and now also have 2 ParkZone planes, Cub and Decathlon. I have also recently acquired the ParkFlyers Cessna 182, but that is a four-channel ship w/ ailerons. ParkFlyers does have a 3-ch version of the 182, but I haven't flown it.
If economics is a factor, check out Shun Da J3 Cub from GiantSunToys.com, under $100 plus shipping. All you need are 8 AA alkalines for radio, as everything else is included. James, the owner, provides excellent customer service and will help you out with more suggestions. Good scale looks, hands-off stable, enough power to loop with a shallow dive. Will even fly in a light breeze, but above 5 mph it's best to have an experienced pilot around. It will definitely ROG but will take practice to do so successfully.
The ParkZone cub is a very gentle flier, also all inclusive. It 'floats' better than the SD cub, but is also more sensitive to wind conditions. I would probably suggest the Super Decathlon as a second plane, as the larger control surfaces make it more sensitive to pilot inputs. Both these planes are more expensive, but there are some good deals to be had on eBay if you look around.
Hope this helps,
Joel
