RCU Forums - View Single Post - skymaster fi5 setup
Old 08-24-2005 | 09:36 PM
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: skymaster fi5 setup
ORIGINAL: steveline9
Hi all, wondered if anyone has jr 8411s on elevators on sm f15. These servos are giving me 5mm total slop on elevator leading edge, is this acceptable? Also useing dubro heavy duty plastic servo arms and clevis, i think these will be strong enough, is this ok?
Regards Steve
Steve,
Slight slop is normal when using 8411's due to the gear lash inherent with this servo. 5mm seems a bit much. Can you take a picture of your linkage setup, would help us to see if it can be improved any?... Is there any play in the linkage or is the slop strictly from the servo itself?
