Got a new Blade CP, got a problem, Please read.
Well i took it out of the box, and tryed to fly it, obviously kept shooting to sides, my first ever try at flyign a heli, so i charged it for about an hour and than draiend it out again, and charged it off and on, i messed with the gyro and proportion pots a little throught the day, and i also notcied that sometimes when i am spiining the rear prop turning on the ground the rear prop spasms out and goes full throttle than stops and doe this a lot, especially when i take off the thing spins really fast, even after i adjust it so the prop spins at full throttle with the pitch its still not enought to stop the heli from turning, i called the shop and they said my collectives were off, so they fixed them and i got back and i noticed that the back prop didn't have enough power to stop the torq from the main blade, and it wouldn't lift off the ground, and it has ALWAYS drifted way to the left even if i adjust the screws, than i left it wide open trying to get air and it died ( my battery was drained ) so what are you thoughts on this? is my heli screwed up?
