RCU Forums - View Single Post - need electronic help
Old 10-24-2002 | 05:17 PM
zomack1
Default need electronic help
I have designed and scratch built an aircraft around the fan unit from the kyoshi T-33.
the particulars:
the d/f unit is the stock one that was in the kyoshi T-33. I can only describe it for identicication. There are two (resistors?) green w/102K marked on them. the entire unit is approx.4" and has an approx. dia. of 3". The battery-6-cell 7.2 volt 1500mah
The E.S.C and reciever are from gws. This is the equipment out of the gws zero arf, and powered by a 7-cell 8.4 volt 600mah.
My question: Can I use the d/f battery to power the esc and reciever without burning them up?
thanks to all
