Update Artes Jets Eagle !!!
Hi Jettset99,
Are you talking about the TJT 3000 'Eagle'? If so, its rated thrust is 27.5 lb continuous @126K RPM. The 'TEMS' ECU will not let you go any higher so please don't expect the 30+ lb thrust level in your tests.
If you got the JG-100 'Eagle' kit with FADEC ECU I don't know if the same software limit applies. Please note that the JG isn't included in the AMA application that just went through on the TJT version.
TJT/JG at 34 lb is a military spec, to my knowledge not for sale to the R/C community. Who quoted you an the 34lb engine? That being said, I have test run one of these at 132 K, an awesome sound, temp is starting to get on the higher side, and it makes pretty serious thrust!!! I wouldn't expect to get 50 hrs of runtime at 132 K though.
Thx,
Kelly
