RCU Forums - View Single Post - Bonehead move: stripped carb threads
Old 08-25-2005 | 04:06 PM
Bodge's Avatar
Bodge
Default RE: Bonehead move: stripped carb threads
It's a bit late now the damage is done, but using spring washers on the the carb mounting screws can lead to stripped threads. This is because you cannot feel the threads tightening - the spring washers absorb the tension somewhat but then the threads give.
Just use ordinary flat washers or even none at all with some thread lock.
