RCU Forums - View Single Post - pizzaz
Thread: pizzaz
Old 01-09-2002 | 11:12 PM
HighSierra's Avatar
HighSierra
Default Pizazz Wing Gap
I have a Pizazz myself, seen 3 others and have herd dozens more, all of wich have the gap.... mine is pretty concistent at about 1/16 to 1/8 inch. Everybody I've herd from or seen including myself just filled it with epoxy.... kinda a bummer but if you do a nice job you'll hardly notice it afterwards. Since it sounds like you're just starting I'll throw you a couple other tips.. Throw away those stupid CA hinges and get some nice ones with the metal pin... An even better thing to do is to look at you LHS for some stiff wire rod that's the same diameter and the Hinge pins and instead of the pins run one length of wire thru all 3 hinges... much stronger. I've got a Saito .72 on the front, and my 1600Mah NImH battery against the firewall to get it to balance out at about 4" behind the LE (I found H9's reccomendation for the CG making the plane fly too nose heavy and damn hard to hover... I'll start inching my battery pack back towards the tail to het better hovering). It's a great plane... Flys crazy but also can be so calm.
Enjoy
