RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 08-25-2005 | 06:39 PM
  #282
Fishmasterdan
Default RE: gas fuel with glo plug no ignition
This is non sceintefic, but I noticed adding nitro to the mix inceases the temp of the motor too much. I ran some gas/methanol/nitro/castor mix and while the bench run it seemed to run fine. When in flight it seems the motor got WAY to hot. It got hot enough to melt the solder joint off the glow plug.
