RE: Another prop question?
That may be true, but the 9-inch prop is 23.4% less in swept area than the 10-inch prop. THAT'S where the pull is. The thrust must overcome the drag. What you might gain in airspeed at idle, you lose because the prop can't overcome the drag.
Dr.1
