RE: Saito 65 Running Problem
Thanks again for the replies.
Bill It looks like my engine is the middle one with the metal throttle arm. I will start the LS out flush and go from there. Adjusting like you recommended. Sounds like you have had alot of experience with Saitos. Which is good for those of us that need help, I know when they are right they run great. I have a Saito 100 on a 4-star-60 and it runs great. But it took me alittle bit to get her dialed in.
Bruce, I also thought about the bearing But I sent it in to HH and they went over the whole engine and replaced both bearing and the push rod tube seals. They charged me $78 bucks to fix her but it wasnt any better than before. They sent a note saying it was running fine but it was not. Thanks for the thought.
Jim
