RE: In flight glitch - please help diagnose
Let us know what you find. Might help someone else with the same symptoms. Sounds like, after 10 mins. something is heating up and shorting out causing everything to go haywire.
Another thing you might try is, take the prop off so it isn't so dangerous first, Then get it to act up, then unplug each servo one after the other, to see if it straightens out with any particular one.
