The reason they have rear and a front side joiners is because the rears' are a little bit bigger in width. VF wanted me to sand down the front side of the fuselage where you slide in the joiners. I did not want to do it so I sanded down ONLY the part of the joiner that goes into the fuselage and not the part of the joiner that goes into the wing. This is only regards to the right side. The left side is "OK" They said that work, too. Hopefully, I will be ok. I was concern about changing the dihedral of the wing.
What do you all think? (I was born in the North and can you see the south is getting to me? LOL!!
