RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
Also......as soon as I converted it to a taildragger......problems ended on that nasty take-off stuff !!!! See my NEXSTAR TO WARDUCK
thread and you will see pics of it as a taildragger. The factory trike gear was just to sensitive. Even tho I filed a flat spot on the shaft
and "perfectly" lined it up before my first take off.....a couple of easy landings later.....it had to be re-aligned.
