ORIGINAL: RysiuM
1. Increase compression (I need to shave about 0.5mm from the bottom of the cylinder. I should be able to fit it on my lathe.
It took me almost a hour to mount the head on 4-jaw chuck. But I got the bottom surface running true with accuracy less than 0.001 inch (0.025mm). Then in 10 minutes on low rpm (to not introduce any vibrations) I shaved 0.5mm of that (+/- 0.01mm)
Next problem. The top of the cylindr had some burned oil so the piston didn't want to go higher. Carb-cleaner, wooden stick, and paper towel did the job cleaning the top of the head.
I checked compression - I don't have tools but I can feel it is much better. Feels like MVVS 1.6.
Tomorrow I will replace the head (I didn't do any porting yet) on my first magneto ignited engine. I will see if I can get better rpm. Can I just swap heads on these engines? Just for testing?
RysiuM
