RCU Forums - View Single Post - Official Mayhem Thread
Old 08-27-2005 | 03:28 AM
  #509
gdc02
Default RE: Official Mayhem Thread
here are instruction to use the new ckermann rack
I hope this helps out guys; Thanks again and here are the other instructions.
1.) Remove the original steering link.
2.) Insert flathead screws through the top of the rack on the rear
outer mounting holes. (When looking at the rack from the top you should
be able to see the countersunk screw holes and the outer ends should
sweep to the front of the buggy.
3.) Add 3 washer shims over the screws on the bottom side of the rack
and then add a threaded pivot ball (shoulder to the top) to hold the
washers in position.
4.) Place the black cone washers on the center holes on the topside
of the rack. Insert flathead screws through the top and attach the
supplied locknuts from the bottom.
5.) Next insert the remaining flathead screws through the cone
washers
on the rack and through the front holes on the steering bell cranks.
Attach lock nuts to the bottom side of each bell crank and secure into
position.
6) Attach steering links to the outer pivot balls and adjust for
proper toe.
Last check and make sure the rack moves freely. Note it may be
necessary to remove a small amount material from the plastic bulkheads
for additional clearance.
forward hole gives more smoother steering response
rear hole more crispy steering response
