RCU Forums - View Single Post - TT Pro .46
Thread: TT Pro .46
Old 08-27-2005 | 04:54 AM
LuckyArmpit's Avatar
LuckyArmpit
Default RE: TT Pro .46
Thanx all! Going to take the cowl off and check the throttle linkage first. Get that squared away. I will start fiddling with the needles next. The engine ran real good a few months ago with no problems on transition from low to high. Then, the weather got really hot and I had to lean out the high end a bit. Also gonna re-check the tank position too whilst I'm in there along with all the servo screws etc.
Might as well do some preventive maint. once I have it apart. Which is what you should be doing anyways every so often.
Dave...
